Community > kelp hatchery > New Resource: GreenWave’s Kelp Nursery Operations Manual
margaret_aydlettM
  • margaret_aydlettM
    margaret_aydlett
    GreenWave’s Kelp Nursery Operations Manual is hot off the press! This guide includes the latest techniques and updated best practices to help operators produce high-quality seed and run more resilient nurseries.
    Drawing on a decade of experience in regional seed production at our nursery, the manual brings together everything you need in one place: clear, step-by-step guidance for every stage of nursery work, plus build lists, reference charts and diagrams, and troubleshooting tools covering setup, water processing, seed maintenance and transport, contamination management, and more.
    Together, these resources are designed to strengthen regional seed systems, connect nursery operators around shared practices, and build a strong foundation for consistent, scalable yield across regions. I'm looking forward to discussing all things kelp with you!
    Read and download the manual: https://hub.greenwave.org/lms/resources/kelp-nursery-operations-manual/
  • tristan_sT
    I've skimmed through the manual and can already tell that it took a tremendous amount effort. Congratulations and thank you for this highly informative and comprehensive manual! I believe many will greatly benefit from it.
    Cheers!
