Community > processing + markets > GreenWave's Processing Setup
jwhisJ
    GreenWave just shared some details about their expanded kelp processing plant including photos and videos of the setup. Check it out!
    It's a modular processing line with a repurposed industrial firewood conveyor that feeds kelp into a grinder with clog-resistant gear teeth. The shredded kelp drops into IBC totes you can easily move with a pallet jack between processing steps.
    Processing has scaled up from 50K to 250K pounds of sugar kelp seasonally without needing a massive facility. Everything's mounted on wheels, requires minimal power, and you don't need to be an engineer to operate it. Hoping that the new facility serves as a replicable example for ocean farms across the country.
    If you have questions, you can watch the detailed video on Processing Prep or @toby_sheppardbloch who runs the plant.
