<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using wine&#x2F;fruit presses for fertilizer production]]></title><description><![CDATA[<p>Hi everyone,<br /><br />We recently completed our first harvest from our algae farm. We're growing Laminaria ochroleuca, Laminaria hyperborea, and Saccharina latissima (brown kelp species).<br /><br />Our goal is to produce a liquid fertilizer from the fresh algae. For now, we're starting small-scale – just testing the process before scaling up.<br />We plan to:<br />Chop the fresh algae<br />Press it to separate the sap (liquid fertilizer) from the solid press cake<br />Preserve the sap with citric acid or potassium sorbate<br />Dry the press cake for further processing (powder, pellets, etc.)<br />Our question:<br />Has anyone here used wine presses or fruit presses for pressing algae? We're looking at a manual prensa de lagar (wine press) for our first tests.<br />Does it work well with fresh, wet algae?<br />Is the pressure sufficient to break open the cell walls?<br />Any tips or things we should watch out for?<br />We've read that screw presses are ideal for larger volumes, but for now we want to keep it low-budget and start with a manual press.<br />Any advice, experiences, or recommendations would be greatly appreciated!<br /><br />Thanks in advance <img src="http://hub.greenwave.org/community/assets/plugins/nodebb-plugin-emoji/emoji/android/1f33f.png?v=7ca1406b8dc" class="not-responsive emoji emoji-android emoji--herb" style="height:23px;width:auto;vertical-align:middle" title="🌿" alt="🌿" /></p>]]></description><link>http://hub.greenwave.org/community/topic/1029/using-wine-fruit-presses-for-fertilizer-production</link><generator>RSS for Node</generator><lastBuildDate>Sun, 28 Jun 2026 04:41:12 GMT</lastBuildDate><atom:link href="http://hub.greenwave.org/community/topic/1029.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 19 Jun 2026 15:44:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using wine&#x2F;fruit presses for fertilizer production on Tue, 23 Jun 2026 00:53:27 GMT]]></title><description><![CDATA[<p><a class="plugin-mentions-user plugin-mentions-a" href="http://hub.greenwave.org/community/uid/9032">@nora_22</a> Goal is to break cell walls to release contents--so some sort of hydrolysis (enzymatic, acid or alkaline) before pressing will yield the richest liquid fraction. Warm or hot water will also assist.  Regardless of method titrate some different concentrations--the more gentle the extraction the higher recovery of bioactive compounds.</p>]]></description><link>http://hub.greenwave.org/community/post/3131</link><guid isPermaLink="true">http://hub.greenwave.org/community/post/3131</guid><dc:creator><![CDATA[toby_sheppardbloch]]></dc:creator><pubDate>Tue, 23 Jun 2026 00:53:27 GMT</pubDate></item><item><title><![CDATA[Reply to Using wine&#x2F;fruit presses for fertilizer production on Tue, 23 Jun 2026 00:43:22 GMT]]></title><description><![CDATA[<p><a class="plugin-mentions-user plugin-mentions-a" href="http://hub.greenwave.org/community/uid/9032">@nora_22</a> we've done it for kelp. We used the model where water is added to fill the bladder and maximize press, not a manual screw one. A bit time consuming for the clean up in between batches but definitely an option. I suggest adding some warm water right before pressing to really maximize extract. But I've seen it work with some success. Hit me up if you have any questions- <a href="mailto:spencer@scrcconsult.ca" target="_blank">spencer@scrcconsult.ca</a> </p>]]></description><link>http://hub.greenwave.org/community/post/3130</link><guid isPermaLink="true">http://hub.greenwave.org/community/post/3130</guid><dc:creator><![CDATA[spencer_serin]]></dc:creator><pubDate>Tue, 23 Jun 2026 00:43:22 GMT</pubDate></item><item><title><![CDATA[Reply to Using wine&#x2F;fruit presses for fertilizer production on Mon, 22 Jun 2026 19:34:58 GMT]]></title><description><![CDATA[<p><a class="plugin-mentions-user plugin-mentions-a" href="http://hub.greenwave.org/community/uid/9032">@nora_22</a> I'm tagging a few people who may have insights, given some recent work with screw presses in the Northeast and Alaska. <a class="plugin-mentions-user plugin-mentions-a" href="http://hub.greenwave.org/community/uid/46">@toby_sheppardbloch</a> <a class="plugin-mentions-user plugin-mentions-a" href="http://hub.greenwave.org/community/uid/6">@lindsay_olsen</a> <a class="plugin-mentions-user plugin-mentions-a" href="http://hub.greenwave.org/community/uid/7429">@spencer_serin</a>: Any insights you can offer would be greatly appreciated! </p>]]></description><link>http://hub.greenwave.org/community/post/3127</link><guid isPermaLink="true">http://hub.greenwave.org/community/post/3127</guid><dc:creator><![CDATA[kendall_barbery]]></dc:creator><pubDate>Mon, 22 Jun 2026 19:34:58 GMT</pubDate></item><item><title><![CDATA[Reply to Using wine&#x2F;fruit presses for fertilizer production on Fri, 19 Jun 2026 22:18:25 GMT]]></title><description><![CDATA[<p><a class="plugin-mentions-user plugin-mentions-a" href="http://hub.greenwave.org/community/uid/9032">@nora_22</a> We are using a fruit screw press to extract biostimulant from Sargassum and you really need to crank it down to get the liquid and so think a manual version will not be very effective. The press we are using is fairly inexpensive (~120 USD) and can process several kilos of biomass at a time (closer to 1 kg for the 9 L size we use). You will want to thoroughly mix all the fractions as you will notice the color and viscosity is different between the first and second pressings (we did 2 pressings) and it will separate upon sitting. Hope that helps! <br />Best wishes,<br />Loretta</p>]]></description><link>http://hub.greenwave.org/community/post/3125</link><guid isPermaLink="true">http://hub.greenwave.org/community/post/3125</guid><dc:creator><![CDATA[loretta_roberson]]></dc:creator><pubDate>Fri, 19 Jun 2026 22:18:25 GMT</pubDate></item></channel></rss>
